Could my tune be off that much???
Check out this thread:
https://ls1tech.com/forums/drag-raci...rt-my-car.html
If you don't feel like reading: I added headers, intake/TB, pulley, 3.5" driveshaft, & 12 bolt 33 spline w/Eaton. Should the stock tune be OK? I lost power, due to the heavier drivetrain, I know that. But shouldn't the extra mods make up the difference? Maybe not without a tune??? More info in the link above!
Thanks, all help is appreciated!
Keep it comin guys.
You made major changes even though they are just bolt on. Fuel/air and back pressure. I hope you see some gains after it's tuned but you may have to go to a bigger cam to benefit from the changes you made. There's no end to it after you start down this road.
BFG recommends about a 2 second burnout. I don't even use a line lock anymore. I just spin em from the box to the line. You can definitely get them too hot and lose traction.
Keep it comin guys, thanks for the input!
