PE tuning after ported heads
Old 11-20-2003, 05:17 PM
XFiveLiter's Avatar
Question PE tuning after ported heads
I currently have a cam only car tuned w/LS1 Edit. Once I put heads on will a/f at WOT be effected? Could I run at the track w/o tuning or should I richen it up a little to be on the safe side, untill I can get it on a dyno? thanx
Old 11-20-2003, 10:55 PM
LS1Tech Sponsor
Slowhawk's Avatar
More than likely it will be affected.I've seen them go either way.Too rich and too lean depending on the Heads.
Old 11-21-2003, 12:15 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Might run a touch lean IMO, I would borrow a MAF T and have that handy. After all, you will make more power and thus use more gas.
Old 11-21-2003, 04:02 PM
XFiveLiter's Avatar
Yeah that's what I figured. If I make it slightly rich w/edit, I can lean it out at the track w/the MAFT.
Old 11-22-2003, 06:46 PM
XFiveLiter's Avatar
Another question...Would the maf keep the a/f ratio the same, so I wouldn't need additional tuning? Or is WOT tuning more like speed density?
