Newby problems in HPtuners with LS1 engine Swap
Old 09-06-2009, 07:19 PM
vannatta20's Avatar
Default Newby problems in HPtuners with LS1 engine Swap
I have a LS1 out of a 2001 camaro. When ever I get on it surges and cuts out. I am new to HPtuners so I could use some help. Please help! Can't wait to get this 68 firebird on the road
[PCM] P0358 - Ignition Coil 8 Control Circuit (Old) (History) (Immature) I see this error but it shows it is old. So that currently is not the problem?
[PCM] P0412 - Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1 (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0418 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1 (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0443 - EVAP Purge Solenoid Valve 1 Control CKT (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0449 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0452 - Fuel Tank Pressure Sensor Circuit Low Voltage (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0480 - Cooling Fan Relay 1 Control Circuit (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0481 - Cooling Fan Relay 2 Control Circuit (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P0645 - Air Conditioning (A/C) Clutch Relay Control Circuit (Pending) (Old) (History) (Current) (Immature)
[PCM] P0713 - Transmission Fluid Temperature (TFT) Sensor Circuit High Input (Old) (History) (Current) (Immature)
[PCM] P0740 - TCC Enable Solenoid Circuit Electrical (Pending) (Old) (History) (Current) (Immature)
[PCM] P0748 - Pressure Control Solenoid Circuit Electrical (Pending) (History) (Immature)
[PCM] P0753 - 1-2 Shift Solenoid Circuit Electrical (Old) (History) (Current) (Immature)
[PCM] P0758 - 2-3 Shift Solenoid Circuit Electrical (Old) (History) (Current) (Immature)
[PCM] P0785 - 3-2 Shift Solenoid Circuit Electrical (Pending) (Old) (History) (Current) (Immature)
[PCM] P1810 - TFP Valve Position Switch Circuit (SES) (Pending) (Old) (History) (Current) (Immature)
[PCM] P1860 - TCC PWM Solenoid Circuit Electrical (SES) (Pending) (Old) (History) (Current) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Complete
Heated Catalyst: n/a
Evaporative System: Incomplete
Secondary Air System: Incomplete
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Complete
EGR System: n/a
Old 09-06-2009, 08:41 PM
4SFEDSS's Avatar
Most of those are emission related codes that shouldnt cause that problem. Judging by all the trans. codes are you using an older style trans? But back to your problem, are you loging with a wideband to make sure your not going lean? Do you have a sufficient enough fuel pump to provide 58-60 psi? Does the ignition coil 8 code come back after you clear it? Have you dataloged while trying to get it to act up, it should be pretty obvious where the problem is coming from after watching the log.
Old 09-06-2009, 09:46 PM
vannatta20's Avatar
I changed the trans to a manual. The fuel pump is a new walbro 255 so that should suffice. Soon as I clear the codes in HPtuners it shows right back. I just dont understand why it still shows it as a history code after I cleared in Hptuners? Also what does imature mean?
Old 09-06-2009, 09:57 PM
4SFEDSS's Avatar
Its there because it was a previous code that came up, as long as it doesnt say current I wouldnt worry about it anymore. Im not sure how many drive cycles has to happen before it gets out of the history. Not really sure about immature.
Old 09-06-2009, 10:08 PM
vannatta20's Avatar
Thanks for the help. It ran great before I relocated the coil packs and now it has some issues. I made custom length wires and maybe I made a bad wire or two?
Quick Reply: Newby problems in HPtuners with LS1 engine Swap
