4L60E and Edit Tune-Any Way This Could Happen?
Strange problem after Edit tune.My trans seems to start in gear selected,OD-car barely moves,D-moves a bit better than OD,if you start in 1ST and manually shift thru the gears it works OK and locks up in OD.
A new trans was put in because we thought my stocker gave up but the new one is doing what the old one did,same problem.The old trans worked perfect on the way to the dyno.
Any thoughts if this could be Edit related?
