Raising the rev limiter with edit?
what have you changed? there are parameters in the engine tab and the transmission tab.
the WOT upshift. Set your RPM upshift value to maybe 200-300
RPM lower than your rev limiter (more slack for the 1-2 may be
needed if you run up fast) and creep your MPH points up from
below (like on my car I use 41, 82, 125MPH with 3.23s and
6000RPM shifts, 6250RPM limiter). MPH too high will leave you
hanging on the limiter until you let off the gas and then it will
upshift.
Did you start with gear and tire scaling, in Edit's speedometer tab?
