i need to know how to power the PCM to run the engine on a test stand. which pin do i need to supply 12 volts to to get it to run the engine? and is there anything else i need to do?
Prolly cause you didn't give enough info for one, and two you should probably put it in the conversions and hybrids section, or wherever, but not in the tuning section......
Might not hurt to tell everyone what PCM you are using....
98 pcm, I have the blue and red harness with everything to hook it to the engine. The body harness is still in the car. I just need to know what I need to do to make the pcm come alive without the vehicle being present.
