tuning with hpt 1bar maf rtt?
Can I still do an sd rtt with this? All I'd have to do is fail the maf like normal correct? Also, once I have my ve tables dialed in can I just adjust the airflow vs. Hz maf table till my ft's come together?
thanks.
thanks.
You still have a secondary VE to contend with (and likely will be stuck in the Lo Octane spark table)...
HPTuner's has changed their licensing and now, you get access to ALL of the custom OS's once you buy one. Go back and use the 1bar SD OS on your original OEM file and save it as something noting that it is a 1bar SD file. Open it up and use compare to compare it to your current MAF file. Use the compare window to move all of your current tables over to your new SD file and pickup tuning from there.
