Erratic timing during spool up...
Old 10-22-2009, 09:05 AM
Turbo 6.0's Avatar
Default Erratic timing during spool up...
The car is a 2009 C6 vette with twin turbos and a HP Tuners 2 bar operating system.
The timing is smooth and accurate to the timing table until I start to roll into the throttle. Then the timing starts to fluctuate by 5 degrees. I think that the rapid changes in the timing might be what's causing the KR. AFR is 11.2 everywhere and the timing in boost is only 10 degrees.
Any Ideas?
