View Poll Results: intake swap?
intake swap with no re-tune
5
50.00%
wait on the swap
5
50.00%
Voters: 10. You may not vote on this poll
re-tune for new intake manifold?
ok so i just dyno tuned my 99z28 after my 6.0 swap. my question is ...if i replace my stock ls1 intake manifold with an ls6 manifold, do i have to re-tune?
FAST78, 85mm MAF,80mm TB & injectors before retune
I had a HP tune after the street stripe cam, then added a FAST78 intake manifold.
I was hopping the PCM would learn this new intake manifold.
I'm planning on reaming out the opening of the fast78 to 80mm and adding a
zo6 85mm MAF and 30lb injectors then mods will be done for this 346CI motor
and one final tune.
you're thoughts on this plan
Thanks
and one final tune.
Thanks
and one final tune.
Thanks
and one final tune.
Thanks
To the OP the Trims can only do so much, and when at WOT it doesnt use the the 02s for fueling its all MAF and off the PE table
EDIT: when using the Z06 MAF you need the 5 pin adapter because the IAT sensor is integrated into the the MAF.
Lid, bigger MAF
Yes I think you're correct about the 75mm MAF good for 500RWHP.
?since I'm only at 380RWHP the 85mm MAF maybe a wasted effort? or could possiablly make car run worse?
I'm curious about enlargeing the MAF ? when you installed the 85mm MAF did you have to get a larger air lid for it to fit?
I haven't bought any of this stuff yet, I'm just planning.
Thanks
Thanks
It really comes down to what you want to do with the car in the future. If you plan on getting heads, a matching cam for the heads, then dont waste your time doing things twice, but if its a budget minded street car, your stock MAF and a Ported TB will get the job done. You would still need to tune your car and get the STOCK MAF recalibrated to get it to run optimal....but its all on what your budget can handle.
I was thinking do a few small mods before this retune plus when I installed the FAST 78 I have my suspions on not glueing the MAP sensor good enought (or the glue has hardened and cracked) creating a everynow & then check engine light.
If I have to remove the intake to reglue mite as well open it up a bit.
Yes it's mainly a street car, my plan is to mile it up as it is, really can't use all the power on the street tires it's making w/ a street stripe cam and LTs.
Looks like I'll have the man retune for the intake and just enjoy it for a few more years, then go all out and hog wild.
Thanks Guy's for excellent feedback
thx for all the info so far guys. im still contemplating throwing my ls6 intake on there and seeing how much it will learn before i re-tune. my other option is just waiting untill i get my new heads but not to sure when i can afford that. so throwing on the ls6 intake is tempting right now.
If you have to pay for an additional tune, I would NOT do it and the car will run fine. Your only going to gain a couple HP from the LS1 to the LS6 manifold.
IF you brought your car to a tuner that give you free upgrade tunes, then Id stop by, but he wont change much anyway.
ok so guaranteed i am getting the car tuned after the intake swap thats no problem. im learning a ton right now since im new to tuning. so my options right now are pretty simple. A- do the swap and ride without re-tuning for the intake for about 3 or so months until i put on the new heads and then do a dyno tune with new heads and intake. i do daily drive the car but pretty much locally. as far as racing goes i dont plan on any track time until the heads and tune are finished. but maybe a little street fun here and there. B- just wait on the swap until im ready for the heads and do everything at once. im just at a crossroads because the intake is just sitting there waiting to go on and i just made 395rwhp without it. haha 4??rwhp just sounds fun and pretty much guaranteed attainable with the intake. i definitely dont want to hurt anything so let me know what you guys think. thx a lot guys everyone here is awesome!
