Converting from A4 to M6 tune
I've done a complete motor and tranny swap, using a 99 pcm which turned out to be for an A4 and I also installed the 1 bar OS in it. Is there a way to use one of the tunes in the HP tuners repository and change the VIN so that I have a full M6 tune?
Copied all the differences from an M6 file but still my reverse lockout was not getting signal from the pcm. I performed a complete write using the M6 base and now it is working as intended.
A complete tune is needed in case of swap.
I see. I thought I remembered trying to do that for some reason when I first got my software and it wouldn't accept it due to the vin or something, it's been so long I don't remember exactly what my issue was. Thanks for clearing it up.
