Weird decel problem?
I have a weird lean condition when I let off the throttle in my truck and start to decelerate. I'm running speed density in open loop and dfco is turned off for tuning purposes. The only way I can keep it from surging with the throttle closed is to jack up the ve numbers in the low map area below 25kpa to add a bunch of fuel to get it back to 14.7afr. Everything else with my tune has worked fine for two years now but I know that something isn't right with low map area being set to 120% ve when 30kpa and up is normal. Anybody got any ideas? Could be in the tune or mechanical? I have went over everything in the tune a hundred times and can't find anything unusual.
What do you have in your "default minimum pulse width" table? They might be to low for your injector to open, which will cause that exact problem.
