Dissabling the rear O2's & AIR
Old 02-26-2010, 06:39 PM
1fastkingcab's Avatar
Default Dissabling the rear O2's & AIR
I am about to install TSP long tubes on a 01 C5 Vette, I already have HP Tuners but I have never deleted cats before, what DTC codes do I need to dissable?
Thanks Guys.
Old 02-26-2010, 11:39 PM
racecar's Avatar
Bank 1 sensor 2, Bank 2 sensor 2. Everything that has sensor 2, set it to 3No error report, and it will work fine. I tried that for several years until I got tired of the nasty O2smell every time I warm up the motor, and at some stop lights. I installed high flow cats this year. I like the cleaner smell, I would never go back to straight pipes. Still made 480rwhp with the new cats.
Old 02-27-2010, 09:17 AM
Ok thanks, thats what I figured. What about the AIR system I have looked a few times, but all I see are AIR DTC's that mention Bank 1 I don't see any in the list for bank 2 or does it matter since there in only one pump and both banks feed off the same pump?
Old 02-27-2010, 09:26 AM
2xLS1's Avatar
O2 & Cats
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
P0140 HO2S Circuit Insufficiency Activity Bank 1 Sensor 2
P0141 HO2S Heater Circuit Bank 1 Sensor 2
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
P0160 HO2S Circuit Insufficiency Activity Bank 2 Sensor 2
P0161 HO2S Heater Circuit Bank 2 Sensor 2
P0420 Catalyst System Low Efficiency Bank 1
P0430 Catalyst System Low Efficiency Bank 2
AIR
P0410 AIR System
P0412 AIR Solenoid Relay Control Circuit
P0418 AIR Pump Relay Control Circuit
P1415 AIR System Bank 1
P1416 AIR System Bank 2
Old 02-27-2010, 02:02 PM
ND2RACE's Avatar
You'll also want to shut off cat overtemp protection, it won't make much difference other then it just isn't needed. It adds a little extra fuel under conditions were it thinks the cat would be getting hot.
Even with the codes off it will still run the air pump.
Old 03-03-2010, 12:03 AM
Darksol's Avatar
Under the hood are two fuse blocks on the drivers side. One will have the fuse for the AIR pump, pull the fuse. That's what I did after tuning till I buy headers and pull it out. Now I don't have to listen to it whine at me anymore
