I Need A Tune!!!
I Need A Tune!!!
i need to know if there is anyone in oklahoma or texas that can tune a ls1 for a reasonable price. just got finished with my set up. i could barely get it to start, and when i did, it fouled the plugs within 5 min of the break-in. my combo is as follows:
383 ls1
12.5-1 cr
ms4 camshaft
factory ported heads flow appx 330 @ .600
gmpp single plane intake
upper elbow plenum
90mm tb
42lb green top ford injectors
udp
160 stat
lt headers
ofy
6-speed
i am sure i am leaving something out, but any help would be appreciated. thanks
383 ls1
12.5-1 cr
ms4 camshaft
upper elbow plenum
90mm tb
udp
160 stat
lt headers
ofy
6-speed
The House is Rockin'
im sure you can find somebody local. if your interested in a mail order tune, try EFI ALCHEMY out of jacksonville, fl.
here's there site http://www.efialchemy.com/
or pm "DOC"
they're great guys to work with!
or pm "DOC"
thanks, but i think i have a differ problem as well as a lack of tune. i pulled my plugs last night, 5 out of the 8 looked like i was running rich and the 3 others looked like it was running lean. i think i may have an injector issue. i bought them used from a member here and did not have them checked before install. i am going to put my factory ones in and go from there.
