I keep setting a P0153!
I keep setting a P0153 ses code.....I have LT headers....I know the code says it is bank 2 sensor 1...so I replaced the 02 sensor on the passenger side..the precat one (in the header)...no luck code came back...then I replaced the o2 wire extensions....same thing..code came back. What else can it be?
I thought Bank 2 sensor 1 was the the 02 in front of where the cats used to be...I have read this in other posts...Anyone else? Please correct me if I'm wrong on this.
"Sorry, let me clarify, and in addition, their respective rear codes. Yes Bank 2 sensor 1 is Passenger front or pre cat sensor."
wrencher
B1=left/drivers side W/#1 cylinder
B2=right/passenger side W/#2 cylinder
S1= pre-cat
S2= post cat
Now for the slow response code, is it possible you have an exhaust leak,even a pin hole?
Ever had to repair the wiring harness besides the extentions?
Can you scan the PCM's data stream is the O2 staying noticably lean or rich?
S1= pre-cat
S2= post cat
12 Second Truck Club
Another possibility, I used copper gaskets and permatex copper sensor safe RTV to fix the leaks. Could the RTV or copper gaskets have ruined them?
How about anti seize? Is there anything in it that could kill 02's?
wrencher
They are sensitive to contamanation it will make them slow & inactive.
It all depends on what kind of compound they are exsposed too.
Most everything automotive now a days says if it is O2 friendly.
If your gonna use somrthing make sure it says this.
