MS4 tuning high altitude
Hi ,i have a camaro LS1 2001 with Full bolts on,full exhaust ,PRC stage 1 heads ,MS4 cam ,Fast 92/92 and SVO 30injectors with 4.10 gears
i just want to order a mail tune from frost ,but i have a doubt that the mail order tune for MS4 cam works good here in Mexico City that alttitude is 8000 ft
some help is appreciated
You can order a mail order tune from Frost that 'works' at altitude. I am no where near as high as you (~5400'), but here is what happens.
When you first turn your key to on, the PCM via the MAP sensor 'calculates' your barometric pressure. That along with ECT, IAT, etc is enough information for your PCM to determine airmass and fueling.
Of course your WOT kPA will be probably only be about 70-75 kPa..but the main point is you can confidently order a properly configured tune, regardless of elevation.
It will work..What octane gas do you have there?
Yes, just let Frost know you are at high altitude. Sometimes you can get away with running a little more spark at higher elevations (since your cylinder pressure is lower).
You have picked a good tuner. He can set you up just fine.
Good luck..and yes use that 92 Octane!
