HP tuner/wideband question?
I am running this setup with no problems. yes you should be able to tap the 0-5v signal wire to pin#?? on the interface and ground(the interface) to the same source on the car you are grounding the actual wideband sensor module. Certainly the plx isnt the BEST wideband out there but I have had great results with it.
Hp tuners has a custom PID for the plx sm-afr so YES(to answer your ?)
