Inj Flow Rate table - L76 Intake
Does anyone have an Inj Flow Rate table for the 39lb/40lb injectors that came with the GM L76 intake (Part# 12590123)? Not sure if anyone ever got the manufacturing specs for these injectors. I looked them up in the bin repository, but got two different results. Right now i think my Flow rate vs KPa table is off and I want to make sure its right.
Thanks in advance.
Thanks in advance.
Found this post:
https://ls1tech.com/forums/pcm-diagn...or-values.html
Although, when i looked up the 08 Vett in the Bin Repository, i noticed that the table for the Vett is actually 33 columns and my PCM is 17 Columns. I assume to just split the difference, but just curious what others have done.
The LS3 IFR cells between 400kPa and 480kPa (6 cells) map to the LS1 IFR cells 0kPa to 80kPa (17 cells)...
You will have to interpolate those 6 cells to fit the 17 cells in your LS1 IFR table.
can you post what you ended up with? This is what I ended up with and I am not sure if I got the correct info.
Inj flow v Kpa
41.72966 42.03969 42.34972 42.65974 42.96977 43.27980 43.52782 43.77584 44.08587 44.27189 44.45790 44.64392 44.82993 45.01595 45.26397 45.51199 45.69801
Inj flow v Kpa
A little off...
calculate this: ifr = 41.74*sqrt((400+x)/400)
where x goes from 0 to 80 in steps of 5 (i.e. 0, 5, 10, 15, 20... 80)
The first and last values should be the same as those in the calibration file respectively (41.74 and 45.72).
