Where is the wire to go to the temp gauge from the PCM?
Old 05-29-2010, 03:34 PM
pwrtrip75's Avatar
Default Where is the wire to go to the temp gauge from the PCM?
Is there an output on the PCM to go to the temp gauge?
I have a 99 f-body PCM/harness. I have this in a BMW and am trying to find the signal output to run it to a gauge. I found nothing on the pinout sheet.
I looked here.
https://ls1tech.com/forums/conversio...swap-faqs.html
Old 05-29-2010, 04:20 PM
Happy Jim's Avatar
There isn't one, the temp sender only feeds the ECU for it's own benefit. If you want a guage in the dash you will need to fit a sender yourself (I fitted mine in the other head by removing the blanking plug by the bulkhead and fitting an M12 to 1/8th NPT adaptor).
Regards
Jim
Old 05-29-2010, 04:54 PM
poconojoe's Avatar
On the 2002 PCM, if you're using for an upgrade to the 98 -bodies, you can do a segment swap in the tune, with a fuel segment from an expess van and end up gettng an output to run the temp gage in the f-body dash, somethimg simular might be able to be done here
