New motor in - Problems
Old 06-01-2010, 12:32 PM
CJJones87's Avatar
Default New motor in - Problems
So I finished putting the new motor in today and went to try and crank it up. First odd things I noticed: Water temp gauge is pegged, oil pressure gauge is pegged, battery voltage is reading 0. I also found it weird that the mileage did not show up and the security light stays on. Fuel pump is not attempting to prime the rails or doing anything for that matter. Just replaced the oil pressure sending unit with the new motor, so I know that is not bad. Cranks over but still no fuel. Thanks for your help in advanced.
Old 06-01-2010, 01:06 PM
HUNTER02SS's Avatar
Check your grounds. Did you re-install the grounds on the back of the head. There should be 3 ground wires there.
