Need HP Base Tune for T-Rex cam
I just purchased a car that has not been tuned yet. I looked through the HP Tuners repository and did not find anything close. Does anyone have a HP tuners base tune for the following mods:
Engine
-346 LS1
-T-Rex V.2 Cam (242/248 .608/.612 110LSA)
-PRC GM 5.3L Stage 2.5 Heads
-Mahle -4cc Forged Flat tops
-LS2 Timing Set
-LS6 Ported and Shimmed Oil Pump
-GM LS6 MLS Head Gaskets
-ARP Rod bolts and Main Stud kit
-LS6 Intake
-Racetronic's 37# injectors
Exhaust
-Hooker Painted LT's 1.75" primaries w/ 3" collector
-TSP X Pipe
-Dyno Max Bullets dumped before the axle
Trans
-4L60E Built my Paul McKay of Reginalds in Columbia, TN
-Pro-Built Automatics Rebuild kit Designed for 750+ HP Applications
-28,000lb Cooler remote mounted w/Perma Cool and Summit relay kit
-4200 Midwest Nitrous Converter
Rearend
-GM 10 Bolt
-3.73 SLP Ring Gear and Pinion
Engine
-346 LS1
-LS2 Timing Set
-LS6 Intake
Exhaust
-TSP X Pipe
Trans
Rearend
-GM 10 Bolt
