Looking for a close tune?
I need an EFILive tun.file that will get my car running. My car has a tune for a way different motor and will only start and stall. Here is a rundown....
1998 Z28
Stock ci./comp. LQ4
242/244 610/612 112 LSA
Stock LS6 Intake/Injs.
Stock LS1 306 Heads
PRC Dual Springs (.650 lift)
NGK TR6 Plugs
Taylor Thundervolt 10.4 Wires
80mm Throttle Body
Pacestter LTHeaders (no air/egr)
Racetronix Fuel Pump and Wire Kit
10.1/1 Compression (Roughly/Almost Exactly)
M6
If I need to put any other mods on here just let me know what I left out. The problem I am having is the car fires right up and goes to 2000rpm and stays there for about 3 seconds and then just dies out and shuts off?!?! I need to atleast make it idol so I can get it warm and fill the cooling system. If anyone can help me with this I would greatly appreciate it. Thanks....
1998 Z28
Stock ci./comp. LQ4
Stock LS1 306 Heads
NGK TR6 Plugs
80mm Throttle Body
M6
