Off idle/part throttle stumble
Old Sep 6, 2010 | 07:36 PM
99MUSTANG5.3L's Avatar
Default Off idle/part throttle stumble
I have a 2004 5.3L that I put into a 2001 Mustang that I am having this issue with. Everything is from the donor truck;ecu,harness,TAC,pedal,etc. When you first tip into the throttle it stumbles pretty bad and also if you hold the rpm's constant and then add more throttle it stumbles also. I had the ecu mailorder tuned for a stock motor(which it is). I'm running a walbro 255 pump externally right at the tank to a c5 filter/regulator and used the factory evap purge line as the return to the tank. I haven't checked pressure at the rails because it revs fine after the initial stumble. Idle is fine also.
I can check live data on my Actron scan tool,but don't really know what to look for. Any help or ideas would be appreciated. Thanks,Mark
Old Sep 7, 2010 | 05:49 PM
Anyone??? Forgot to mention that there are no codes.
Old Sep 7, 2010 | 06:07 PM
sreve's Avatar
post a log file or data
Old Sep 8, 2010 | 08:35 PM
Michael02hawk's Avatar
My guess would be the Throttle Follower settings.
Old Sep 9, 2010 | 02:39 PM
I'll try to get info from my scan tool up tomorrow.
