What constitutes as abuse
Old 02-01-2004, 06:24 PM
Flyer's Avatar
Default What constitutes as abuse
In EDIT I see the Abuse Mode windows and tables. What triggers the Abuse made to pull timing?
Old 02-03-2004, 01:11 AM
Flyer's Avatar
Surely someone knows ...
Old 05-28-2004, 11:13 PM
marc_w's Avatar
Bump...
I'm curious too.
I have a side question here...
My settings in HPTuners:
Abuse Mode RPM: 1500
Abuse Mode %TPS: 5
Abuse Mode Speed: 255 (MPH)
Is abuse mode "turned off" because of the 255mph speed?
Old 05-28-2004, 11:18 PM
SidewayzOZ's Avatar
I believe so. I had heard this somewhere else before.
Old 05-29-2004, 01:27 AM
deezel's Avatar
In the engine tab in Edit it says:
If RPM > xxxx and
if MPH < yyy
In the Trans tab it has RPM, %tps, and MPH, but no indication if < or > is used.
I just zero out the tq reduction table for abuse mode...
Old 05-29-2004, 12:57 PM
Moderator
jimmyblue's Avatar
There is engine abuse, and there is transmission
abuse. I got into some funky "stuff" with some of
these tables and zeroing one, does not save the
other from acting. I haven't gotten a good
explanation yet, just some hints. I will have to
go back now and see where I left off, that seems
to be good. I believe I jacked up the Engine abuse
RPM and dropped the MPH to 1MPH, and left the
trans alone (as everything I did, seemed to bring
back a sporadic "hang" on hard acceleration).
If you aren't getting hit by some mysterious loss
of power then you could just leave it be. I think
finer/broader abuse controls are part of the next
release, maybe there will also be better explanation
of action in the docs (?).
