Where could I spice into for power only when the key is on?
Old 02-03-2004, 08:48 PM
9 Second Club NA
Dragaholic's Avatar
Default Where could I spice into for power only when the key is on?
Im trying to supply power for my lockup and I need a place where I can splice into that will only give me power when the key is on. It will be coming from the side of the tranny, so the best place from there. If someone can point me in the right direction and tell me which wire it is, I would appreciate it so much. Thanks
Old 02-03-2004, 09:23 PM
red ws6 99's Avatar
I have my accessories tied into relay that gets its signal from the air conditioner fuse.
Gary
Old 02-04-2004, 02:02 AM
black_yukon's Avatar
Any pink wire in your fuse panel should work.
Old 02-04-2004, 11:12 AM
slow's Avatar
the fuse panel on the drivers side, has "ign" and "acc" ports, that you can take a .25 male disconnect and slide it into the terminal.
That is where i would go, if it draws any power.
If you have an aftermarket radio, you can tap into the powerwire for that.
Those are the 2 non splice into factory wires options.
if you want to splice into factory wires, you can get power from the TCS or ASR switch, it should be pink, and even if you don't have it, you will have the connector on 98+ cars.
Ryan
