Help with Delivered Torque
Old 02-06-2004, 08:59 PM
JimMueller's Avatar
LS1Tech 20 Year Member
Default Help with Delivered Torque
I've used two different methods to street tune the car:
A ) Leave the HOT stock, and adjust PExRPM by 99% until I get knock, then raise it in the offending RPM range by 1% until the KR disappears. Continue until all PExRPM ranges have been completed. I did not touch WOT timing at all.
B ) Starting with my dyno tune, I reviewed the AFR graph and adjusted the PExRPM in a few RPM ranges by 1% to get them closer to 13:1 across the RPM range. I then multipled the PExRPM table by 102% to richen it to an estimated 12.6 to 12.8:1 on the dyno. I then added timing in 2400-2800 .52-.72, 3200-4400 .4-.84, and 4400-8000 .52-1.0 until I got knock then dropped it back until it was gone in the respective cells. I have my WOT enabled at approximately 20% TPS, btw.
I've been told that the Delivered Torque PID does not generate accurate numbers - but that it does show relative gains and losses. To that end, I logged one run with (A) tuning, and two runs with (B) tuning. The results are as follows:
Code:
RPM	Tune B	Tune A
1500	572
1600	569
1700	569
1800	577
1900	582
2000	578
2100	575
2200	572
2300	563
2400	558
2500	560
2600	564	567
2700	572	570
2800	574	572
2900	585	580
3000	592	585
3100	600	595
3200	609	602
3300	618	618
3400	625	626
3500	637	631
3600	639	646
3700	640	642
3800	643	645
3900	640	648
4000	638	643
4100	636	643
4200	637	637
4300	639	638
4400	635	640
4500	670	645
4600	649	646
4700	650	662
4800	648	656
4900	648	651
5000	635	641
5100	635	641
5200	626	632
5300	622	632
5400	618	624
5500	623	629
5600	606	623
5700	613	618
5800	610	609
5900	597	599
6000	582	593
6100	565	581
6200	550	568
6300	544	570
6400	527	560
6500	522	543
6600	506
6700	433
6800
Total	24463	24651
It's about the same up until 3500, then it starts to separate. I did not have samples for the blank entries. For some reason I was having a hard time creating an Excel chart with RPM on the x-axis and TQ on the Y-axis, and having it plot both results on it.
I tried tuning method "B" because others had tried method "A" and found themselves very lean when they went to a dyno. They said that even w/o KR they were running very lean.
Comments & thoughts on the differences? Does tune A really make an additional 20+ torque above 6200?
Old 02-06-2004, 09:36 PM
Moderator
jimmyblue's Avatar
Only at one datapoint, the curve in general
seems to favor B. I'd just make them two
series on a scatter plot and eyeball the curves
for both peak and heft.
Quick Reply: Help with Delivered Torque
