tune rechecked, still maf code. ecm bad?
ok i resent ecm back had it double checked said it was the car issue not tune! car idles same with or without maf no change. checked wiring o2 sensors replaced battery, car set for while during all this so replaced it. for life of me i cant get it to idle worth crap throws p0103 code every start. begining to wonder if the ecm took dump on me.. i tried diff maf sensor too. already had to put new plugs in it fouled out already. when i tried to view the live data on it with hp it showed no ve tables ??what am i missing here car has sit for 6 months i cant seem to get this thing goin
thanks
hey frost the car is not suppose to be in sd. even if it was it should quote should run better than it does car is not drivable. i let a friend talk me into sending to his tuner, big mistake!! tuner supposedly never does sd so i would think its not there but. anyway im in process of gettin a ecm from friend to try if its the ecm it will be boxed and at ur door step soon thanks again!!
Give your guy a fair chance to make good. I SUPPOSE it's possible that a MAF fails and puts out some high freq, but I've never seen or heard of it. Borrowing a buddy's MAF could rune that out. The code definitely means that the car is in SD though whether intentional or not. Maybe the MAF fail freq was inadvertently set low.
