Security Kill switch
Old 02-11-2004, 06:24 PM
Camaro00_SS's Avatar
Default Security Kill switch
Recently I've been getting the "no-go" on starting the car; I turn the key to ignition, and the PASSKey system activates, killing the starter circuit and the fuel pump. That annoying "SECURITY" light comes on, and I have to sit there for about 3 minutes until the system resets itself. Thought I might have a bad resistor in the iginition key, so went and bought a new one. Nope, same thing happens!!
Anybody have any idea what might be wrong? I just had a custom tune put in, but we didn't go anywhere near the security functions.
Any help would be appreciated, this is getting old quick!
Old 02-11-2004, 06:32 PM
ChevyThunder17's Avatar
Did they use LS1 Edit? If so, bring the car back and have them disable the Passkey crap, it's in LS1 Edit. I removed mine, and no problems.
Old 02-11-2004, 10:27 PM
wrencher
wrencher's Avatar
Yea a tuning program can remove this for you.
Other than that the lock cylinder VATS pellet reading contacts, the small 20 gauge wire breaks or begins to & causes these type problems.
Old 02-12-2004, 09:57 AM
NoGo's Avatar
If that doesn't fix it you can also bypass the VATS physical interlock by grounding the appropriate wire on the BCM.
On the 00 cars I believe it is the dark blue wire on the BCM bundle, but check that before you just ground it.
Good Luck
Old 02-13-2004, 09:43 PM
HUH? Got the concept, just have no idea where to locate it.. send me a link or info, pictures, then I can do it..thanks for the help!!
