What do you use to datalog your LSx?
I'm new to the LSx PCM world.
I used to use a $70 moates cable and free software to datalog on my laptop.
When I went back to find a solution for the LSx PCM, I found that it cost $400.
Since then, I've seen a few other options including wifi and bluetooth transmitters in around $175-200.
I'm interested to hear what others are using.
If the solution happens to also feed Wideband O2 gauges, that would be even better; but it's not a requirement.
I use the HP Tuners Pro interface. I can't remember how long it will log for but it's a good bit and I can play back on my laptop. I can also log through that to my laptop for as long as I have battery on the laptop. Logging too long is pretty pointless usually because at some point you have to sift through your logs if you want to learn anything.
But no, I wouldn't sit there and read it every night just for fun.
I currently use hptuners also, but the cheaper version that does not support widebang logging. The pro version does have that capability, it's more money though.
I used to have a dashhawk v2 that would not only display certain parameters but also had a feature to log data which you then downloaded to a laptop and viewd.
Either way, it's going to run you more than $70. You can find some cheap deals on used stuff though.
On top of that, it introduces another potential voltage offset to that analog signal.
I use EFILive FlashScan V2 in BBL/standalone mode... it reads the AFR and Lambda from my Innovate LC-1 using serial comms and stores them as a pids in the logs... the logs are stored on a 2GB card plugged into the V2.
(Innovate widebands/gauges support daisy chained serial comms)
The V2 lets you view the pid data on its LCD while logging is in progress.
When I return from a logging session, I take V2 to my PC, I upload the log files, use the software to view the log files, edit the tune file, and write the new tune onto V2 (SD card)... I then take V2 to vehicle and flash the PCM and do a new logging session.
When viewing log files and editing the tune file on a PC, the scantool software links the logged pids into the tables in the tunetool software... i.e. the tables in the tune have the operating cell highlighted from the log pids (i.e. the pids index the x and y axis of that table).
What is your objective and platform...?
It's a 383 LT1 with a 24x conversion and LSx PCM.
I use datalogs to make sure things are running properly.
In this case, I have a mailorder startup tune; I'm going to have to make sure
it's running properly before I strap it to a dyno. I don't like surprises that
turn a dyno tune day into a waste of everyone's time.
In the future, I'll use it to review conditions from runs at the drag strip and the impact of any changes I might make.
It will also be important when I install a DP N20 setup so I can verify that it is safe to arm the system.
I was looking at a dynojet Wideband 2 LCD system, it looks like I can log ODBII data and a single wideband input.
That might work out well for me. I wish it could do two external widebands since I run a dual 3" exhaust.
