A bunch of stuff going on after turbo build. HELP. VID INSIDE.
I tryed looking up a few things, but nothing really sounded like what my car is doing so i took a short video to show everyone what the problem is so far.
http://www.youtube.com/watch?v=GU54X6JIQWg
The car clicks super fast when the ignition is turned on and the brights light is flashing to the clicking. Know their may be more lights flashing but electrical tap is covering most of them
Doors lock, but dont unlock. The power mirrors are working, but the headlights arent. Thats about all i know at this point. Took out the BCM and check the T shaped joints, and they looked good. Going to get some resistors tomorrow and try the VATS delete mod.
ANY IDEAS ON WHAT THE HELL IS GOING ON?
I had the same problem after mine was down for awhile. Chase the chassis grounds on the front harness that bolt to the radiator support back into the harness and there are like 5-6 grounds that meet together and there is probably corrosion causing you not to get proper grounds. Pm me if this sounds confusing.
Check your grounds. When I first got my car back together it was doing some of the same things. Turned out I had a few ground wires disconnected. Either that or you cut out something under the dash you shouldn't have....
Ok ended up I had a few ground that were not hooked up. Fixed um and everything is acting alot better, but still not perfect. Know the lights work, turn signals, flashers. EVerything accept the windows and the lock button. Still doing the same ding ding, when you try to unlock it. So i guess im going to try the VATS thing and see if that is the problem with that.
