408 Crank sensor problem HELP!!!!
New motor with a 6.0 n 4'' stroke Eagle crank(24x). Car starts & runs but keep getting crank position not verified code. The idle air controller keeps closing all the way once car starts up, so it dies after running for a while. Tried another crank sensor same problem. At start timing is 23 degree, timing stays the same while idle but fuel goes crazy. All verified through H.P. Tuner software. Any help would be appreciated
Jerrymcalester@aol.com
214-601-6600
214-601-6600
