Car ran fine, drove fine then died...now it won't start.
Old 06-05-2011, 12:42 PM
01SOMZ28's Avatar
Default Car ran fine, drove fine then died...now it won't start.
I just got done doing a cam swap. Started it for the first time yesterday, it ran fine and sounded fine. Let it run for about 15min to make sure everything was good, but while it was running my SES light was blinking. I decided to take it down the road, only made it 4 blocks from my house and the car just died and would not start at all. Does anyone have any ideas?
Old 06-05-2011, 12:51 PM
poltergeist 02's Avatar
will it start when you hold the throttle open a little?
Old 06-05-2011, 01:18 PM
01SOMZ28's Avatar
Nope. It just cranks over and will not fire.
Old 06-05-2011, 04:43 PM
67RSCamaroVette's Avatar
The first step is to check codes. A lit SES light is ok, but a blinking one is NOT good. Pull codes and get back to us..
Old 06-05-2011, 05:28 PM
01SOMZ28's Avatar
It came on, flashed, then went off. Did it probably two times. I hope nothing major is messed up....
Old 06-05-2011, 05:29 PM
Was it running rich/loading up? Check the plugs, check fuel pressure at the rail..
Old 06-07-2011, 06:27 PM
01SOMZ28's Avatar
If the little red wire coming off the alternator came disconnected, could that cause my car to shut off and not start again?
Old 06-08-2011, 02:40 PM
mike.d's Avatar
yes that turns on youre alternator check battery
Old 06-08-2011, 04:26 PM
01SOMZ28's Avatar
But would that cause my car to just shut off while driving?
Old 06-08-2011, 05:00 PM
chasgiv3's Avatar
If it's the wire I think it is then yes! It'll kill the car from running by interrupting the power being fed back to itself. This is how we wire our rear mounted battery kill switches. Alternators require a field current to produce electricity. Without it there's no power and your car dies!
The wire supplying the field current is often referred to as the "exciter" wire. The drawback of this arrangement is that if the warning light fails or the "exciter" wire is disconnected, no excitation current reaches the alternator field windings and so the alternator, due to low residual magnetism in the rotor, will not generate any power.
I hope this makes sense. I'm an electrical engineer so sometimes I make folks have that far away look in their eye.....LOL
Old 06-08-2011, 05:54 PM
01SOMZ28's Avatar
Is the little red wire on the alternator referred to as the "exciter" wire?
I hooked my computer up to it just a little bit ago to get some more information. The first code that popped up was U1088 - Loss of Communications with SDM. Then i got codes U1000 and B1000.
Old 06-08-2011, 08:37 PM
chasgiv3's Avatar
Not sure but keep in mind that dropping power to everything may bring up some funny results. Not sure
Old 06-08-2011, 08:38 PM
01SOMZ28's Avatar
I just reconnected the small red wire on the alternator and it did nothing. The car still cranks and will not fire.
Old 06-09-2011, 07:15 AM
Nitroused383's Avatar
Try disconnecting the battery, than cycle the key to drain all power. Reconnect the battery and see if it starts. My friend had a blinking SES light in his GTO when his cam bolts backed off, it was screwing with the cam position sensor. Check your cam position sensor. What timing chain did you use?
Old 06-09-2011, 10:05 AM
01SOMZ28's Avatar
I used an LS2 timing chain.
Old 06-09-2011, 11:34 AM
mike.d's Avatar
grounds on back of the head maybe loose can you hear fuel pump
Old 06-09-2011, 11:38 AM
01SOMZ28's Avatar
The grounds on the back of the head are tight and i can hear the pump.
When i had it hooked up to HP Tuners yesterday it said the car was in 3rd gear but it was park.
Old 06-09-2011, 11:41 AM
thunderstruck507's Avatar
Tach move when cranking? If not check the crank sensor and wires.
Old 06-09-2011, 12:19 PM
01SOMZ28's Avatar
Tach does not move. I've noticed that the MPH gauge jumps every once in a while when i move the shifter or turn the key on.
Old 06-09-2011, 10:31 PM
01SOMZ28's Avatar
The car has no fuel and no spark. HP Tuners isn't getting any tach signal and no other signals from the cam sensor...nothing. I tried 2 other PCM's and that didn't help any. All the hot wires and ground wires going into the PCM check out fine. I have no idea what is wrong....The previous three codes do not show up now but a different one has shown up but i can't remember, something like C0188 but i'm not 100%.
Quick Reply: Car ran fine, drove fine then died...now it won't start.
