LS1 Editing at the Track Questions
I just bought my LS1 Edit. I have never seen anything more confussing . I have searched both here and LS1tuning.com, and a couple of other sites. I would like just a quick/easy answer, without all the flaming that usually I see on the other posts. There has to be a simple answer to these questions.
I am in the processing of added heads/cam, and a bunch of other goodies . I will have the injectors, MAF, fuel pump - basically everything I will need to handle any amount of HP the SS can put down.
I had a very good tuner do my tuning. I am sure it will need some minor tuning when I get it back together and put it on the dyno. The tuner will be available to fine twik the tune. I have A-tap and will be monitoring the runs.
My questions are: (remember, no one will be at the track to help this old fart)
1. If I want to try (on the engine) a little more timing, how exactly do I add timing for the entire 1/4? I'll be launching at 6000+ rpm, and I doubt I'll be going under 5000 for the entire run.
2. If I want to lean it out just a little, how exactly do I lean (or richen) it?
3. My LTFT need fine tuning at the track, same question, how?
Sorry about all the questions, but I really need some help. Previously, I had a stock engine and was able to "tune" it using just the MAFT. Now this is an entirely different ball-game.
My mods are just to long to list here, but can be found at my web site link in my signature.
Thanks
David
Thanks
David
1. To add timing, you will need to modify the High Octane Spark Advance table
2. To lean out WOT, you will need to play with the 'RPM' button in the Power enrichment section under the FUEL tab.
Originally Posted by Navy David SS
You mean none of the tuners on this site can answer any of these questions?
Really need some help
Thanks. David
Thanks. David
2) To lean out your car you are going to use the PE vs RPM table located under the engine - fuel tab. To lean out your car simply type the desired percentage shift in the lower right text box and pressy "Mult %". Press the "Apply" button to make your changes permenat. Save your file and upload it into your car.
To add fuel (enrichen your car) you will want to multiply the PE table by values greater than 100 (ie 101 to 110). To reduce fueling (lean your car) you will want to multiply the PE table by values less than 100. (ie 90 to 99). Any changes to this table should be between 90 and 110. Never multiply this table by a value less than 90 or greater than 110.
3) LTerms are for emmissions, not performance (despite the general concensus). If they are less than 15% ignore these at the track.
Good Luck,
Kevin
