1999 camaro pcm pinout issue
I am confused what the pink wire number 19 on the blue connector goes to... It says ignition positive volatge. I am wondering if this goes to the fuel pressure sensor in the fuel tank because it calls for ignition feed ( I am guessing thats ignition pos. volt. )... and that 19 pink wire is the only positive voltage iginition wire on the pcm. Please help.
