No lockout for Reverse P0803
Old 03-10-2004, 08:23 PM
bandit_99's Avatar
Default No lockout for Reverse P0803
Got a problem, and was hoping somebody could shed some light on my situation.
Just before I put my car into storage (99 C5) I was on the freeway shifting from 4 to 5 and I tapped Reverse....no damage- just a quick growl to let me know that it was not in 5th. I tried once more and the same thing happened. My trans is not locking out R when the car is in motion. I pulled the code and its P0803 1-4 Upshift Solenoid Control Circuit (M/T) -B
I replaced the solenoid on the trans and that is not the problem. We found out there is no voltage going to it-
So are there any simple things I can check? I'm worried its my PCM- which seems like a pricey fix...
Any thoughts?
Thanks,
Dave
Old 03-10-2004, 08:28 PM
slow's Avatar
any chance you have your CAGS and reverse lockout plugs wrong?
i know on the f-body, no voltage, you can't get reverse, you need to energize the lockout to allow you to go into reverse.
Ryan.
Old 03-10-2004, 08:32 PM
Smitty's Avatar
is that the only code?....have you check all fuses?
Old 03-10-2004, 08:40 PM
bandit_99's Avatar
Ryan.
No, this won't be it. I've had cags defeated via LS1 edit for 2 years when this happened seemingly out of the blue. See, I think it failed in the open position- so its not locking anything out. I installed a new solenoid that was in the closed position and the only gear I could use (if I remember) was reverse and 2 I believe....
I'm not the most mechanically inclined, so forgive me if my post makes no sense. Thanks!
Old 03-10-2004, 08:42 PM
bandit_99's Avatar
Fuses- AOK.
Here are the other codes, all are History:
B0502 RH DRL Relay Circuit
B0503 RH DRL Relay Circuit
B0507 LH DRL Relay Circuit
B0508 LH DRL Relay Circuit
I just pulled these out last night.
Quick Reply: No lockout for Reverse P0803
