Racetronix impedence converter connectors?
I am about to purchase the Racetronix injector converter harness and the AEM box.
I am still waiting on my OEM wiring harness to show up from a 1999 5.3 silverado though. So I don't know what the injector plugs look like.
My question is, there are two options for the injector INPUTS where it plugs into your OEM harness.
Option #1 is the typical bosch EV1 connector (which is what my injectors are and wont plug into the factory harness)
Option #2 is "V8 USCAR Connector input option"
Do I need option number 2 for my factory wiring harness? Or pick option #1 and still have to buy the converter plugs separate?
Again... This is for where your factory harness plugs into the converter harness. NOT where the converter harness plugs onto the injectors.
Ok, looks like I need this as this is exactly what my lq4 truck injectors look like. I just hope the 5.3 injectors have the same connector as the 6.0.
This is a Multec II connector which is what appears to be on my LQ4
http://www.racetronix.biz/itemdesc.a...%2DM2M&eq=&Tp=
LS1TECH Sponsor
You will require Multec2 input connectors.
You should contact online-orders@racetronix.com before your order ships Monday afternoon to arrange to have these connectors specially installed on your harness.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
I bought some EV1 connectors that I was just going to splice onto my OEM harness. But, I may have you guys just install the MultecII injectors.
EDIT: I just emailed you guys. Please look for an email from Satanz31@hotmail.com
