installed pcm, won't run
I just installed my new pcm in my 04 GTO and am having some trouble. The car will crank and fire immediately but after less than a second it dies. I've never swapped pcm's in one of these cars before so I really don't know what the issue could be. It seems to start fine with no trouble but just won't stay running.
Did a relearn for the bcm/pcm and it fired right up. Had to turn key on for 11 minutes, off for 30 seconds, on for 11 minutes three times and it was good to go. After some more specific searching I found what I needed. Thanks guys.
