Question on Pcm Swap...
Well i search and found threads about it.
Im about to swap my 98 pcm to a 01 0411 pcm. I know i have to repin my harness, but i have some questions i dont want to do it and mess it up.
So i need to take off each wire and label it like (RED 1,RED 2, ect.ect) whenever i finish i should connect them back to my same connectors using this diagram?
http://www.ls2.com/boggs/torques/2002pcm.htm
I usually take the 99+ pinout, and on one side of the sheet, next to each description of the circuit, write the pin number that circuit is in on the 98 diagram.
If you wanna get complicated, you could probably do a spread sheet in Xcel.
If you need any help, shoot me an email.
Well i start doing the pinout but got to a problem, i was taking of number 11 from the red connector the color on my connector is green and on the diagram that im using is says dark blue.
This is the diagram that im using http://chevythunder.com/199798_ls1_pcm_pinouts.htm
