P0740 & p040
Old Nov 26, 2011 | 11:04 PM
WSVI's Avatar
Default P0740 & p040
Hi all,
I am a bit confused after going to get emission today. I only have a computer test here in GA and it failed throwing two codes P0740 & P0404. Now the P0404 is egr and I know all the parts and concerns there, I can care less about that one.
But the one that is killing me is the P0740 Torque Converter Clutch Circuit Malf. I have NO Check Engine On. After the test, and trying to find as much info as I can on here and the web, I went for a drive and it seems like the tranny is not locking up at all. It accelerate and shift like normal but once i get to a steady speed it jut stays unlocked in fourth.
If anyone have any info that would be helpful about fixing this problem and/or why I have two codes but no check engine light please let me know.
Oh yeah its a 2000 trans am ws6 A4 COMPLETLY STOCK WITH CUTOUT ONLY
Thanks
Old Nov 26, 2011 | 11:25 PM
2TR's Avatar
2TR
P0404: Disassemble and clean your EGR.
P0740: Change the TCC (lock-up) solenoid and wiring harness. Usually it is the harness that causes the problem because the wires become brittle and the wire is exposed and it shorts with another wire or shorts to ground on the valve body.
Old Nov 26, 2011 | 11:36 PM
WSVI's Avatar
ok thanks. any thoughts of why no ses light?
Old Nov 27, 2011 | 08:19 AM
2TR's Avatar
2TR
When you start the car does it flash? This will confirm light works...
Has the car been tuned previously? Verify someone hasn't blocked these codes...
Otherwise...
Dunno?
Old Nov 27, 2011 | 10:29 AM
WSVI's Avatar
Yes the light works when I start the car. Weird.
Old Nov 27, 2011 | 01:39 PM
2xLS1's Avatar
Both of those codes are set to MIL on 2nd error on your stock 2000 calibration. Closer examination when checking the codes would probably have shown them to be pending waiting to see the errors a second time to turn on the MIL light.
