Charging system issue, alt dropping out under WOT load
Going thru alt, still having issues. Original issue was car kept dropping voltage under WOT load on dyno. WOuld hold steady 14.1 volts, then started dropping to battery voltage for a split secodn then recover to 14.1. It progressively got worse some pulls it would drop to battery voltage right away, sometimes it would drop then midway thru pull then recover. Went thru 3 alternators doing different but similair stuff. Tried volt booster and it would hold at 15.5 for a minute, then started up/down stuff again. Tried sending alt out have it rebuilt, 145 amp in stock case (same person that did KPs and he had no issue for a few years of racing with a volt booster)
First pull 14.1 volts, hit WOT, volt booster did its job 16.4 volts dead rock steady. Thought we were back in business. Next pull it wavered around 16.2 volts +- .5 volts. Pull after that, held at 16, dropped to 14 gradually, midway thru jumped back to 16 v. Each pull getting more and more erratic.
Any ideas?
Any ideas?
1 Post
Check the alternator wire and make sure it's not broken or burned. Mine recently had this same problem and we found the wire had broken off the black plug-in sensor that goes into the alt. We fixed and no issues since.
