07 Heads/Cam/Stall A6 with up-top shifting issues
Been working a ton on my tune with a few people. When you punch it at any speed under 45, it picks up and goes and I wouldn't change anything about it. Anything above 45, there is a major lag. Here's a video of it lagging:
http://www.youtube.com/watch?v=VxH04dUiRBs
You can see, once it finds out what gear it wants, it hauls ***.
Mods are etp 215 heads, g5x1 cam, 3.42 gear, 2800 stall. Before the heads, it didn't have lag when I got on it from 70, but now.. I'm guessing air changed and we can't find out what the computer wants at all.
Tune file: http://www.visionsconnect.com/sm-21.hpt
Any help would be rewarded with praise as if you were my god.
Here's two logs from a tune file back... but the problem was still there, so should be pretty much exactly like my latest tune on there.
http://www.visionsconnect.com/scan1.hpl
http://www.visionsconnect.com/scan2.hpl
Not an issue fix just something I've found so far.
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > DESIRED SHIFT TIME > 0, all cells.
Do the same for all (6) of the following sections >
Base Upshift - Normal
Base Upshift - Special
Base Power Downshift
Min Power Downshift
Base CT Downshift - Normal
Base CT Downshift - Special
Min Power Downshift
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > SHIFT TIME INPUT TORQUE ADDER > from 59ftlb.-398 ftlb. of torque and 0 rpm to 6400 rpm, .300, all cells.
Copy the modified table and paste in all Upshift - Normal tables in the Shift Time Torque Adder Section.
In the Upshift-Special table however use the value of .250 instead of .300 as this will give a slightly quicker shift when in the sport/manual mode.
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > DESIRED OUTPUT TORQUE NORMAL > 1-2 shift > 0 all cells.
Do this for all of the following Normal, Special, and Downshift tables for each and every gear change option available (DO NOT adjust multi):
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > SHIFT PRESSURE > BASE SHIFT PRESSURE > UPSHIFT - X > 1-2 > load stock values and adjust by +5 until desired pressure reached (I use +15), all cells.
Do the same for all tables under Upshift - X, Upshift - Y.
The 'Vette doesn't technically use a Pattern Z so skip any reference to it.
HP TUNERS EDITOR > TRANSMISSION > AUTO TCC > APPLY/RELEASE SPEED NORMAL > NORMAL > 3rd/4th gear only change 0%-75% throttle position > 158.
Do the same for the 5th option as well.
Repeat for ALL shift patterns except HOT (leave stock).
Open up the HP TUNERS VCM SCANNER > TABLE PRIMARY > CLICK ON HPT ICON (MIDDLE TOP) > RIGHT CLICK ON ANY BLANK WHITE SPACE > INSERT > TRANSMISSION > TCC > TCC DESIRED SLIP RPM.
DITTO : > TCC LINE PRESSSURE
DITTO: > TCC SLIP RPM
You will now have (3) seperate new PIDS added.
Now RIGHT CLICK > INSERT > TRANSMISSION > TRANS CURRENT GEAR.
DITTO: > > TRANS TURBINE RPM
You now have (5) new PIDS total added.
Save config. as TCC Slip Config.
NOW...
Go back to the HP TUNERS EDITOR > TRANSMISSION > AUTO TCC > TCC PRESSURE > APPLY RAMP > from 5 rpm - 400 rpm and 74 ftlb. - 369 ftlb., +10.
SAVE AND LOAD TUNE FILE.
The goal is to get the TCC SLIP to 0-20 rpm. Watch the TCC SLIP readings...if not within 0-20 rpm increase pressure by +5 until results are achieved.
NOW...
That's all the info. I have for you! I noticed you have made SOME of these changes already but in different increments. You also have a few other tables that have adjustments but nothing that would cause an issue. Good luck!
