check engine light will not work! why???
Old 01-25-2012, 06:04 PM
kpadlina's Avatar
Default check engine light will not work! why???
is there a bulb that can be changed that I'm not seeing??
my check engine light doesnt come on at all. any suggestions?
Old 01-25-2012, 06:57 PM
2xLS1's Avatar
It is not a bulb. It is an LED that is soldered to the circuit board behind the cluster. I repaired one on an automatic car one time after an idiot crushed the SES LED with a pair of pliers. I unsoldered the damaged one and the one for Skip Shift since it wasn't being used and moved it to the SES position. It requires some de-soldering and soldering skills.
Old 01-25-2012, 07:01 PM
kpadlina's Avatar
pretty rare that a LED would go out isnt it?
how do you get the cluster apart to solder it?
Old 01-25-2012, 08:49 PM
2xLS1's Avatar
Once you get the cluster out of the car it is easy to see how it comes apart.
