Can you program ECU for different Tranny?
Old 03-22-2004, 08:00 PM
ROCNDAV's Avatar
Question Can you program ECU for different Tranny?
I was wondering if an ECU can be programmed for different transmissions. I often run into ECUs for Automatics and really need one for a 6 speed. I know the ECU can be reprogrammed for different gear ratios and fuel curves but what about the tranny? Sorry if this is a newbie question, I just cant seem to find the answer any where.
Thanks in advance,
ROCNDAV
Old 03-22-2004, 08:36 PM
Brains's Avatar
If you can find a file with the same segment 1 ID, you can upload that file and be OK.. So, the short answer is find a file from the same year, with the same segment 1 ID, with the transmission you want..
A better way would be to get the PCM flashed by a dealer with the appropriate image.
Old 03-22-2004, 08:51 PM
ROCNDAV's Avatar
Default Thanks Brains
Cool, so short story: Yes!
That's what I was hoping for!
Thanks for the reply!
ROCNDAV
