just did longtubes, used denso 234-...corvette sensors.now no communication to o2s
car is a 2000 ss, 236/238 cam, ls6 intake, stock heads.......put on longtubes today, or semi assisted, and also did a clutch swap......started the car up and wasnt running too good.....sounded not too good......the car also has an exhaust leak at the header tho.....anyway, drive 5-10 min the SES light kicks on.......i used the denso 234- not sure the rest, but upstream o2s for a 2000 corvette.......i had it scanned, and the scanner said no communication to "BOTH" o2 sensors.......i made sure i routed them nicely away from the headers, and also made sure they were in the clip and the blue key was in the connector.....my question is......Now what? should i go buy bosch 13111s? how do i diagnose this with the assumption that they are both connected, since i just jacked her up and checked?
i also wanna add number one i mean downstream o2s for a corvette, and 2, therear o2s were already programmed out before the longtube header install today.....and i plugged the drivers side o2 into the plug near the A-arm, not the one near the trans......same for the pass side
any thoughts anyone? last night i disconnected the battery so it can learn the new headers and what not til i can get it tuned.....the ses light came on after about 30 miles.....assuming its still the o2s......the car idles much better now, and doesnt stall so much
no my tuner is fairly busy this week......the car drove to the shop and left same day.......so confsed as well.....what fuse do i need to look at that works the o2s? i mean i considered replacing them with ac delcos but dont think it would do much......what would really make both o2s not communicate at all? there is a leak at the header on the drivers side.......theres no way this could be contributing right? because how would that affect the passenger side? how do i monitor them? im sure hes got the proper equipment to do so.
