scanner powers up but cant communicate with pcm??
After having some exhaust work done my predator can't communicate with the pcm. The predator powers up but says I need to turn the key to the on position. It says that while the car is idling. I checked the cid fuse and that is fine. Any suggestions. The car is a 02 z28 . I thought maybe it was the predator but advance auto scanner done the samething.
Sometimes the pin at the obd port gets a lil worn out or loose u can depin it and try squishing it a lil bit and see if that cures the problem sounds like it would be the data line wire ifrc its purple
