15.6V@WOT normal?
15.6V@WOT normal?
Just curious, since this seems excessive. During cruise I have noticed 14.8-15.8V without headlights, A/C, or anything else on, other then whats required.
I am also wondering if this voltage is taxing my HP. If so; is there a way to make changes by using HP tuners?
Moderator
It's abnormal, but there's always the question of "which
ground?" - PCM ground might or might not be the same
voltage as block ground (should be; assume nothing),
which is what the alternator refers its output to for
regulation. That wants checking.
13.9 to 14.2v is normal no load voltage.
The first thing to check is the battery,a bad one can cause
a high charging voltage and testing the alternator on the car
is not a valid test w\o a known good battery. One thing for
sure is the battery won't live long at 15+ volts.
