Tuning for T-56 transmission swap.
Old 11-13-2012, 12:52 PM
WarShrike's Avatar
Default Tuning for T-56 transmission swap.
Okay, I have a T-56 swapped in and want to make sure I have the trans settings as close as possible.
I have a GTO T-56 so the ratios are:
2.97/2.07/1.43/1.0/.84/.63
For my car, I have a 3.42 rear gear and running 275/40/R17s for tires.
What all do I need to change on the speedometer tables? This is running a PCM flashed with the T-5 tables from the dealer. It seems to be a little bit off, but kinda hard to tell since nobody around here does the speed limit.
Current settings are:
Code:
General
VSS Pulses Per
Mile:  43700
Rev - Trans  10.5703
Final Drive Ratio
Drive Sprocket Ratio   0.000
Trans Revolutions/Mile   0.000
Gear/Tire Calc
Current: 7.85
Auto Scale Transmission Tables: Yes
FWD: No
GTO Tables look like this:
Code:
General
VSS Pulses Per
Mile:  47992
Rev - Trans  40.0000
VSS Output Pulses Per
Mile:   10020
Mile - ABS:   128000
Final Drive Ratio
Drive Sprocket Ratio   3.46
Trans Revolutions/Mile   2448.5741
Gear/Tire Calc
Current:
Tire Size: 24.72
Gear Ratio: 3.46
FWD: No
Quick Reply: Tuning for T-56 transmission swap.
