408 having some backfiring issues
Old 11-13-2012, 04:29 PM
backdraft408's Avatar
Default 408 having some backfiring issues
long story short i have a 408 in my 2000 ss that has backfired a total of three time in the past month. all three times car was being driven in town, and has happened when after i stopped at a stop sign and then kind of got on it. my tuner says its not a tuning issue and has to be machenical problem. wondering if anyone has had this problem? whether its a spark plug, timing, fuel, tuning or injector problem i just want it fixed and hoping someone else has been in my shoes.
Old 11-13-2012, 08:58 PM
96capricemgr's Avatar
Last time I had an engine backfire on me it was because I had used the wrong intake manifold gaskets and it had a vacuum leak at the port between the head and intake. This was a gen 1 engine not a Gen 3+ but I would expect a similar result if a port seal got rolled out of it's groove or something during install.
Old 11-14-2012, 01:54 AM
it also seems to run a little on the rick side at idle
Old 11-14-2012, 07:47 AM
If one cylinder is sucking air at the port the O2s will "see" that lean lean condition once it is mixed with the other 3 cylinders on that bank and dump fuel to compensate making the other 3 rich.
Have to remember fueling correction is done bank to bank.
I thought of another case where I had some backfiring, it was a single dead injector on an LT1. One injector was just dripping.
Old 11-14-2012, 11:36 PM
the more i get into it the more its looking like a fuel problem
Old 11-16-2012, 01:00 PM
i know something is wrong when it backfires and blows an muffler off
Old 12-02-2012, 05:42 PM
tjb406's Avatar
i blew 2 off one night but that was a wide plug gap and a lil too much n2o.
Old 12-02-2012, 09:41 PM
Blackpanther99's Avatar
If the fuel mixture is too lean (not enough fuel) you may have a backfire in the intake, have you checked you air to fuel ratio?
Old 12-03-2012, 07:00 AM
Old Geezer's Avatar
Some data logging may do wonders for determining wtf is going on..............
Quick Reply: 408 having some backfiring issues
