A/f ?
Old 03-16-2013, 11:02 PM
stherngent's Avatar
Default A/f ?
I installed a cold air/ram air intake from K&N, Last week. Before I did that I ran my car at the track and my A/F was like 11.9-12.2 now since I have installed this it is 10.8-11.2. My questions are is this commin? I'm assumming I need a new tune. My car has the street heat stage 2 cam with 241 heads stage 3 port job, UDP, headers 1 3/4, 3" tsp y-pipe, slp loud mouth exhaust 3", ls6 intake, pp tb,
Old 03-17-2013, 09:59 AM
flame's Avatar
The Cai likely leaned it out so your fuel trims are adding. If the trims are positive when you go wot they get added on top of commanded. You are right you need a tune to fix it.
Old 03-17-2013, 05:18 PM
stherngent's Avatar
thanks
Old 03-18-2013, 09:27 AM
Hardrvin's Avatar
Shouldn't add it more than previous condition though. Is this a kit that includes the MAF tube?
Old 03-18-2013, 12:13 PM
wait4me's Avatar
Just needs to be tweaked for the new modification. Any change that effects mass air meter readings will mess with the air fuel ratios. It is an easy fix for your tuner.
Old 03-19-2013, 08:28 AM
stherngent's Avatar
so i'm assuming with it doing this after I get it retunned I should see some hp gain?
Old 03-19-2013, 08:38 AM
wait4me's Avatar
Possibly.
Quick Reply: A/f ?
