SD Question
Old 06-20-2013, 12:45 PM
work in progress's Avatar
Default SD Question
Does speed density use data from O2's?
Old 06-20-2013, 12:59 PM
LSX Power Tuning's Avatar
There is SD in OL (open loop) which doesnt use the O2's or SD in CL (closed loop) it WILL use the O2's.
Old 06-20-2013, 01:23 PM
Ferocity02's Avatar
Speed density basically means the airflow is being estimated from the VE table instead of measured by the MAF sensor. You can still use O2's with SD (closed-loop) or not (open-loop).
EFILive's custom operating systems have something called semi-open loop which uses the short term fuel trims only instead of a combination of the short and long term fuel trims. This is what I'm running now with SD and it works pretty well.
Old 06-20-2013, 01:47 PM
redtan's Avatar
Speed density means a lack of MAF input, not necessarily that it will or will not use O2s.
As mentioned, open or closed loop is what differentiates between a tune using or not using the O2 sensors.
Quick Reply: SD Question
