Aftermarket spark cut rev limit
Old 10-19-2013, 08:08 PM
super6ute's Avatar
Default Aftermarket spark cut rev limit
Hi all,
Chasing an aftermarket true 2 step spark cut rev limiter.
MSD and lingenfelter only appear to control launch spark cut. I need to do the max rpm limit also as it's turbo with meth spray.
Car is 2002 LS1. Any suggestions?
Thanks.
Old 10-20-2013, 09:40 PM
super6ute's Avatar
Anyone?
Old 10-21-2013, 09:53 AM
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Default Aftermarket RPM limiter
The LPE LNC-003 and the LNC-2000 can both be used as maximum engine speed limiters.
The LNC-2000 only has one RPM limit setting so if you are using it as a 2-step off the line then you can't also use it as a maximum engine speed limiter.
The LNC-003 has two separate RPM limits so you can have one set as your launch RPM and the other as your maximum engine RPM. You would have the maximum engine RPM always active.
The LNC-2000's are in stock.
We are just re-releasing the LNC-003's so it should be a week or two and they will be shipping again.
Hope this helps.
Originally Posted by super6ute
Hi all,
Thanks.
Old 10-22-2013, 09:05 AM
super6ute's Avatar
Thanks Jason, The LNC-003 sounds like what we need. I'll be in contact.
Quick Reply: Aftermarket spark cut rev limit
